V-Ray 3.30.01 BETA! available for download
  • Originally posted by vlado View Post
    In 3ds Max 2016 we now use the 3ds Max render messages window, which you can open from the menu Render > Render Message Window... - you can right-click in the window for some options.
    Still have problem, sorry for that. I disable "Open on error", but its still appearing
    AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
    2D | 3D | web | video
    jiri.matys@gmail.com
    https://gumroad.com/jirimatys
    https://www.artstation.com/jiri_matys
    https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
    https://www.instagram.com/jiri.matys_cgi/
    https://www.behance.net/Jiri_Matys
    https://cz.linkedin.com/in/jiří-matys-195a41a0
    • Originally posted by Jiri.Matys View Post
      Is there any error or warning in it?
      • Originally posted by Morne View Post
        Is it normal for the samplerate to flip/flop between 2 versions?
        Had an image on for 90 minutes and it went through about 40 passes. Every few passes it changes the samplerate between a version that is mostly white with lot of green and another with a lot of red and blue.
        Yes, it's normal with the new dynamic noise threshold. Every time the threshold is reduced, the number of active pixels (the white pixels in the SampleRate RE) increases.
        So do I:
        1) Instead of 90 Minutes, leave it run for 180 minutes?
        or
        2) Leave it on 90 minutes, but INCREASE max AA of 100 to maybe 200 and DECREASE noise from 0.005 to 0.003
        A) What's the difference of leaving it run for longer and leave it same time but change the AA and Noise?
        It probably needs more time. You can see the current noise threshold in the render messages. If it hasn't reached the final threshold, decreasing the noise threshold in the settings won't change anything for the same render time.
        Increasing the max AA subdivs also won't change anything, not before the sampler completes at least 10000 passes. 40 passes completed equal to about 6 subdivs, so it's nowhere near 100.
        Anyway, it would be best if you can send us the scene.
        Radoslav
        Radoslav Platikanov | Chaos R&D
        • Have a new test on a new VRayAerialPerspective Atmosphere plugin.
Name:	VRay 3.3 new fog.jpg
          VRay 3.3, new sky+VRayAerial, caustics, Forest Pack 5 - render time 5:14
          • I am starting a new project using the beta, however, my render is completely washed out. IRR+LC with V-Ray Sun/Sky
            Bobby Parker
            www.bobby-parker.com
            e-mail: info@bobby-parker.com
            phone: 2188206812
            My current hardware setup:
            • Ryzen 9 5900x CPU
            • 128gb Vengeance RGB Pro RAM
            • NVIDIA GeForce RTX 4090 X2
            • ​Windows 11 Pro
              Yes, Shelac and Blend is not supported. Probably some bought object has that on.
              • Originally posted by glorybound View Post
                [ATTACH=CONFIG]26901[/ATTACH]
                Looks like two times applied LWF.
                  This looks like double gamma to me.
                    Ok, will make sure we are not opening that on purpose.
                    • Please post new issues in separate threads in the Problems section
                      Hello guys,
                      Because this thread is becoming a mess already; can you please start new threads for issues that you encounter with the beta? The "Problems" section of the forum is ideal for it. Thanks! I really appreciate the feedback
                      • Originally posted by savage309 View Post
                        You can send it to blagovest.taskov@chaosgroup.com
                        If it is too big and you need to host it somewhere, I can forward details how to upload it on our FTP.
                        Blagovest,
                        I sent you the scene for testing. So far CPU seems to be going faster than GPU now, something is wrong. I used this scene on 3.2 RT with exceptional speeds.
                        Vlado,
                        What would be the time frame for getting the Vray RT with the old method so I would be able to use it and test it for production. Also I never got access to the nightlies, I was told a couple of months ago I would.
                        • Originally posted by Donfarese View Post
                          You can do that even now:
                          a) Go to Start menu > Chaos Group > V-Ray RT for 3ds Max > Start V-Ray RT render server.
                          b) Turn on distributed rendering for V-Ray RT; turn off the "Use local host" option and add "127.0.0.1" as the render server.
                          Actually I think we did give you access. If you go to nightlies.chaosgroup.com and log in with your user name and password for the download section on our web site, you should be able to see the builds. If not, let me know.
                          • I checked everything and everything was correct. So, I ran a script that kind of sets up my scene, and now it looks good. I went over the settings and nothing changed, so I don't know what happened.
                            V-Ray Gamma 2.2
                            MAX Gamma 2.2
                            VFB sRGB checked
                            Fileoutgamma 2.2
                            This is how I had it and this is how the script has it. Strange, but all is good now.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • in the vray colormapping section, you can choose to apply the colormapping to the image (dropdown choice), and that's what you likely missed.
                              Lele
                              emanuele.lecchi@chaos.com
                              Disclaimer:
                              • Originally posted by ^Lele^ View Post
                                Yes, I think that too.
