CG element integration - Matte reflection
  • CG element integration - Matte reflection
    Long time ago, I remember seeing a tutorial about matte reflection ...
    But I don't find it anymore
    Anyway, today, what I have to do is to integrate a CG element in a photo.
    it's ok to catch the shadow but ... what is the best workflow to catch the reflection pass ?
    Currently, I have my ground with matte object check / alpha contrib. to -1 and shadow & affect shadow
    I have a extra tex-map with a dirt with Reflection occlusion...
    Overall, could you please explain how to do the best way to integrate CG element ?
    Thanks a lot
    (Sorry for my bad english)
    There is no simple way of doing reflection like you would shadow. Typically you would render it in a few render layers. Beauty, shadow, reflected beauty (on other objects) and matte to comp it in. In your case you can set reflective occlusion to be Red/Green so for all reflected objects it will return solid color which you can then use in comp to key in your beauty reflection.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Thanks Morbid,
      In fact, I would like to "isolate" the reflection.
      It's really tricky because the person who will comp, need to have shadow and reflection aside. I have no control on comp...
      I know, it's a shitty job...
      Is there a way to do it all at once?
