Rendermanager advice needed
  • Rendermanager advice needed
    Hy, what soft/plugin can do following:
    all features only must work on a small farm in production mode (bucket)
    submit jobs to nodes
    add remove nodes on the fly
    currently batchcam script and backburner is working fine, but you are not able to add a second node after rendering is started. Even you save dr servers by hostnames in the scene.
    Current „trick“ is to submit a dr job via batchcam to backburner, one node is taking it and involve a second node via the dr info inside the scene. Now when the second node gets offline or „missed“ the startup the vray_dr.cfg would not be read out during rendering and one node completing the job....
    btw what are you using for rendering different stills with light and material variations?
    pulze?
    reindeer?
    thx for info
    Greets Phil
    WS
    DUAL E5-2683 V3 28c/56t @2,6Ghz
    64GB Ram
    ASUS ROG STRIX OC 1080ti
    PALIT SUPER JETSTREAM 780ti
    Node
    I7 2600K @4,40GHZ,
    32GB RAM
    Personal Suggestion (not Chaosgroup endorsed): Deadline.
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      And I think deadline is free up to 2 nodes?
        Indeed it is. And should also allow for forms of meetered licensing (pay as you go, kind of.), i think (with us too. but i have *not* checked, as it's none of my business! :P) .
        Lele
        Disclaimer:
          With Deadline can I have a 64-core CPU render 4 frames in parallel of a single job, each frame being assigned 16 of the cores in that machine?
          Aleksandar Mitov
          www.renarvisuals.com
          office@renarvisuals.com
          AMD Ryzen 9 9950X 16-core
          96GB DDR5
            Keep eyes on this one!
            https://pulze.io/products/render-manager
            Deadline is great tool but way too expensive for small size studio.
            Martin
            http://www.pixelbox.cz
              deadline would be best
                I use BatchCameraRender created by friend of mine / I did not use DR, but other staff is very useful ...
                http://www.scriptspot.com/3ds-max/sc...-camera-render
                  Hang on, what do you mean you can't add a second node after renderign has started witgh Backburner?
                  "Add and remove to selected job" works for me
                  http://www.jd3d.co.uk - Vray Mentor
