displacement map instead of normal map?
  • displacement map instead of normal map?
    im currently fiddling with the whole "bake details from highres mesh into lowres one with normal map" thing.. tried xnormals etc.. i also fiddled with the projection modifier in max.
    it got me thinking.. it would be nicer to use displacement.
    is there a way to generate a displacement map from a highres mesh to use on a lower res version?
    i guess it would need to be a vector displacement map to work correctly...
    But why would you? Surely time needed to render a displacement of sufficient quality would be longer than just rendering the geometry?
      yes but a low resolution mesh is easier to edit and work with. for example at the moment im using a fracture plugin the smash stuff up. doing that on the full15 million poly mesh is basically impossible. at the moment im using normal maps to keep the detail as best i can.
        Also, it could be resolution dependent so a distant object/character wouldn't have to be so heavy.
        Actually in VFX that's what they're doing.
        A displacement map from a high poly version can be generated in xnormal or zbrush for example.
        I tried that lately for a guitar string. I wanted it to have fewer polys in the distance.
        It didn't work unfortunately. It displaced the geometry but it refused to subdivide it. And I don't know exactly why.
        I think the low poly needs a minimum complexity I probably didn't reach..
        German guy, sorry for my English.
