Render times
  • Render times
    I have a pretty large scene that is rendering in an hour with CPU, but when I set it to Hybrid, the render time goes up to 1:45 minutes. I have a Titian RTX, with 24GB of RAM and the scene is taking up 13 GB of that. Why would my render times go up if I am using the same CPU power and adding the GPU to it?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Are you rendering progressive or bucket?
    Add Your Light LogoCheck out my tutorials, assets, free samples and weekly newsletter:
    www.AddYourLight.com
    Always looking to learn, become better and serve better.
      I am rendering bucket
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        You are not "adding" the GPU to it
        GPU (RT) is a totally different render engine to advanced CPU. When using GPU, they're cheating the code to make the system believe the CPU is a GPU. In laymens terms, when rendering GPU, it's accessing the GPU system via a more direct route, but when using the CPU to render GPU, it's using a translator to stop and ask for directions along the way.
        Also, with GPU bucket, it's a relatively new(ish) feature that may not yet be as polished as progressive just yet
        Kind Regards,
        Morne
          Hu? It is using the GPU plus however it uses the CPU, so why would it be slower? I'll try progressive.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Yeah, bucket should be faster though... Strange occurrence
              Not with the GPU engine, bucket isn't faster.
              Will need more work, simply switching to progressive should get a big chunk of time back.
              As to why it should be slower, particularly with buckets, it's because of the waiting around that needs to happen for buckets to be finished (with the GPU engine), as the CPU can't scamper off in the distance by its lonesome.
              Lele
              emanuele.lecchi@chaos.com
              Disclaimer:
                I thought bucket was faster because the GPUs dont have to wait for the CPU to send back what has been computed as in progressive. So in bucket mode every processor has its own area to care about... wrong?
                  In my testing Bucket mode has been always faster than progressive on GPU, to get to the same clean result(unless you are getting stuck buckets maybe)
                  With bucket on GPU, I use .02 noise threshold or even higher, it is very sensitive to noise unlike using Buckets with the CPU engine, where I use .008 noise threshold and sometime lower than that.
                  For comparing the 2, make sure both your results are similarly clean as far as you can.
                  I haven't seen a case where hybird rendering is slower, mostly I have seen the GPU engine to be faster and deal with noise better than the CPU engine.
                  Would be nice if you share both your renders, there was a problem with fur on GPU recently. It used to to get stuck for 15 minutes or so on compiling Geometry, but this was fixed in the nightlies.
                  Muhammed Hamed
                  V-Ray GPU product specialist
                  chaos.com
                    Only case I have seen GPU buckets to struggle (get stuck) is on fur/hair with VrayHairNext material
                    But same happened with CPU engine, this is one of few cases I would use progressive over bucket.
                    Muhammed Hamed
                    chaos.com
                      So, it's about 50/50 to which is faster. I tried GPU again and it crashes to the desktop, so I'll test things on another project.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        When with GPU, you are very dependent on the state of your video drivers, which can get messed up (not just because of V-Ray, mind you.) within the single OS session.
                        If you feel stuff is misbehaving, get yourself a hard reboot, and then try again.
                        Lele
                        Disclaimer:
                          gpu is fun
                          Dmitry Vinnik
                          Silhouette Images Inc.
                          ShowReel:
                            I find that very disturbing . Indeed since switching to gpu rendering my 3ds max and computer restarts became very frequent.
                            do you think that will ever change? Or there might be a tool that checks drivers and tells me live when there is a problem?
                            • #15
                              I updated my GPU to the latest driver and I no longer see the driver error message. Are there any issues with the latest drivers? I haven't experienced any, yet.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
