I've just updated to Vray Next Update 2. I was really eager to try the new Isolate Selected function in IPR. Unfortunately, I'm having some trouble. Every time I select an object the lighting on that object changes drastically. I tried with a few different scenes and the same thing happens. Please check the screenshots below. It kind of defeats the purpose of this feature if the objects get drastically different lighting when isolated. From what I can see, it works fine in the official Youtube demo video - https://youtu.be/vJ-2LJpF5AU?t=37 Maybe I'm not using this new feature properly?
Vray Next Update 2 - How do I properly use the new Isolate Selected feature in IPR?
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
So what happens in your scene is that you very much rely on GI for lighting. When you use Isolate Select, everything besides the selected geometry turns completely black so the light can't bounce and light that object.
I understand your confusion, we are thinking for a good workaround for this case.If it was that easy, it would have already been done
Peter Matanov
Chaos
Ah, bummer. Kind of useless feature for me in this case. I was really stoked when I saw it and the main reason I wanted to update.Here's hoping it will be fully functional in the next update.
Aleksandar Mitov
96GB DDR5
it is very cool feature ,so I would love to see a fix for this too .
Simply, I love to put pixels together! Sounds easy right : ))
Sketchbook-1 /Sketchbook-2 / Behance / Facebook
Does this mean than when the object is li wih bounced light only it will not render?Martin
http://www.pixelbox.cz
I would really like to see this with all the lighting. It could be really a great feature!
But I love how it show texture for selected material node, its cool! Thank you.AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
2D | 3D | web | video
jiri.matys@gmail.com
https://gumroad.com/jirimatys
https://www.artstation.com/jiri_matys
https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
https://www.instagram.com/jiri.matys_cgi/
https://www.behance.net/Jiri_Matys
https://cz.linkedin.com/in/jiří-matys-195a41a0
One more thing - is it possible to show what is behind transparent object? My point is when I edit some transparent glass on table or something, if I enter Isolate Selected feature, everywhere is black and the glass is black too because there is no background, so its impossible to edit it.AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
Originally posted by Jiri.Matys View PostOne more thing - is it possible to show what is behind transparent object? My point is when I edit some transparent glass on table or something, if I enter Isolate Selected feature, everywhere is black and the glass is black too because there is no background, so its impossible to edit it.If it was that easy, it would have already been done
Peter Matanov
Chaos
- Likes 1
Originally posted by slizer View Post
The change that Vlado proposed will fix this case too. It needs a little more testing and if it's ok, you'll see it in the hotfix.AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
