excluding vray light from reflection
  • excluding vray light from reflection
    is there a way to exclude vray light from glossy reflection of vray mat??
    (vray 1.46.14)
    It is excluded in your case. What you see are the highlights from the light. If you need to affect the diffuse lighting only, use a standard 3dsmax light with inverse-square falloff, maybe area shadows and the Affect specular option off.
      Or turn off the glossy highlight in your wall material (set it to 1)
        Not to poke my fingers in you nose Vlado, but what exactly is the difference between the reflection of the light on the wall surface, and the specular hilight of it? Since vray is (or at leas used to be) all about physically correct simulation, would this not make the hilight a reflection in vray terms?
        Signing out,
        Christian
          its a fake reflection of a light source. basically if you turn off your glossy locks and leave highlight glossies at 1.0 then your fine. set the other reflec glossy to your desired amount
            Many people begged for faked highlights for a long time so that's why they are available now. You can easily turn it off (see posts above)
