compositing lens effects
  • compositing lens effects
    Can anybody share tips for compositing Lens Effects? I just found out there's no alpha information for the effects. And I've looked for a Lens Effects render element but if it is there it isn't immediately obvious.
    Thanks.
    They need to be added. Change the layer mode to add in AE.
    You can add a lens effects elemend by changing the dropdown in the lens effects rollout from 'image only' to 'image and render element.'
    German guy, sorry for my English.
      Originally posted by Ihno View Post
      They need to be added. Change the layer mode to add.
      Thanks. I know. But how do I get a file or a channel containing only the Lens Effects out of max?
        I edited my fist post
          Thanks.
          Which rollout is that?
            The one in the vfb
              Thank you!
              The manual isn't very detailed on this ....
              "Mode – Determines if the Bloom/Glare effect will be applied to the final image (in the effectsResult channel), stored into a separate render element, or both."
              Where will the "effectsResult channel" be? Only in a V-Ray RAW output? And which render element is it output as?
                You can find all the render element channels in the top rollout in the VFB (image attached)
                For the glare mode, if you select:
                "Image only" it will only show in "effectsResult"
                "Image and render element" it will show in "effectsResult" and will create a "Glare" render element
                "Render element only" will only create a "Glare" render element.
                You can use this glare render element to composite in photoshop, using a blending mode like lighten
                  Found it. Thanks!
