Will Max Upgrade affect Vray?
  • Will Max Upgrade affect Vray?
    We've been using Max 6 and 1.46.13 for months now - with very good results, and the reason we haven't upgraded to our subscription version of max 7 and 1.46.15 is because we have had a lot of on going projects and didn't want to switch renderer right in the middle of a project. (If its not broke don't fix it is something we strongly go by - we have caused way too many problems for ourselves upgrading in the middle of past projects.)
    If we upgrade our Max6 to Max7, will we need to re-submit our request codes, or is the vray licensing system independant now the license server is running?
    Also, would it be possible to return to max6 (for whatever reason, i can't think what just now) once we have done this upgrade and still use the same vray licenses?
    Thanks in advance.
    Yes, the license is independent and yes you can return to 6 at any time.
    Eric Boer
    Dev
      Is upgrade to max 7.5 also a problem?
      Someone have test it?
      Laurent
        aparently max 7.5 is buggy while it works with vray I heard there are other stability issues.
        Dmitry Vinnik
        Silhouette Images Inc.
        ShowReel:
