multi/Sub-object material preview
  • multi/Sub-object material preview
    Hi
    I'm missing this thing in vray 5's material editor preview.
    See only the first material.
    There's a way to get it back.
    Thanks
    Hi roysgi
    You can switch to the old material preview by enabling this option in Render Setup > Settings > System > Native 3ds Max material swatches.
    Nikoleta Garkova | chaos.com
      Thanks Nikoleta. yes i knew the option of " native 3d max material swatches" but I want to stay with the new preview and at the same time see
      In the materials editor the preview of multi \ sub object
        Chaos Support Hi
        I'm really waiting for an answer.
        It is very difficult now to know what material has been placed on a particular object. For example, windows that consist of glass and a frame and have a multi \ sub-object placed on them, it is difficult to find the material in the materials editor because I only see the first material. Hope I was clear and waiting for an answer
          Hi, apologies for the delay.
          Currently, there is no other option to preview the materials apart from the proposed workaround by switching to the native 3ds max material swatches. This is a known issue and is logged in our internal system (ID number: VMAX-10063). I'll bump its priority additionally and will make sure to let you know when there is any update on the matter!
            Thanks.
            Waiting
              Hi roysgi
              Expect the change in the upcoming Update 1. The preview sphere will be divided in 4 (IDs from 1 to 4), I hope this will be enough.
              Peter Matanov
              Chaos
                Thanks Peter. good news!!
                  Hi Guys,
                  I just wrote this here and got the hint to see over here...
                  https://forums.chaosgroup.com/forum/...j-materialball
                  For me, I find 4 also not enough. wouldn't it be good, when something with 8 or so should be fine? I mean anyway is not the appearance of the material itself at this stage important, rather than recognizing differences along with the Balls inside the Matlib view / Materialeditor self
                  No need to do any visual changes, based on watching changes happening on the tiles. This would be done anyway ever on the mat itself
                  edit: why not slicing it horizontally as much as needed? Or letzt say 8 or 12 slices? This will put a unique view on the Matball and is open for everything.
