Metalness question
  • Metalness question
    May I know if I set metalness to 1.0 without changing the use glossiness to use roughness, will Vray still giving the correct result? what is the correct way to use metalness if I am not using PBR textures?
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    Hi jackieteh
    Use roughness is optional. Glossiness (or its inverse - roughness) controls the overall amount of scattering, depending on the selected BRDF model. i.e. - how shiny it is. If a roughness map is used instead, then you can switch your V-Ray material to use roughness. For more information, please do visit our very detailed blog post on the subject: https://www.chaosgroup.com/blog/understanding-metalness
    Nikoleta Garkova | chaos.com
      Originally posted by nikoleta.garkova View Post
      Hi jackieteh
      I have read the article you post here, thank you very much.
      I try to understand what you have explained here, just want to double confirm:
      Do you mean we can use metalness in either glossiness or roughness workflow, with or without textures is it correct?
      Jackie Teh
        Yep, if no map is present, simply invert the float amount.
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
          Thank you for your clear and simple answer, straight to the point
          Jackie Teh
            Ahah, easy when the question is simple and to the point!
            Lele
            Disclaimer:
