ok I had saying that because I had similar problem but only with color profile of photoshop CS. now I know the issu.Finally it's not the same that you.
But, in max your render is good?
ill leave this question to the gamma people to explain. needless to say though it doesnt like a gamma problem
i've done some tests, i adjusted the gamma in MAX, the ammount is 1.54,
then wen i save the render i use the gamma correction and i imput the 1.54 value and it seams tha is really close now when i open the file in photoshop.
ok! Here is an explanation that might give you some idea of what is happening.
Found by doing a search in google:
"...Gamma correction changes your input, display, and rendered output results across the board, not only for video images. You should not make this decision lightly without understanding the algorithm and nature of the changes to your renderings. Certain bitmap formats do not store gamma values, and some 2D applications do not gamma-correct; therefore, tracking your bitmap assets when mapping or compositing in a multiuser production environment becomes a bit trickier than when gamma is off. If you're in such a production environment, instead of setting Display Gamma to 1.8, you should adjust this setting to match each artist's monitor. With gamma set correctly across all devices, your rendered output should look the same, regardless of your final medium."
