It says it can be configured in the docs but I can't seem to find it.
How change the download location of the Cosmo Browser
Hi AbeTJH
Sorry to say it is not currently possible to change the file path location for the assets. They are saved by default to C:\Users\[Username]\Documents\Chaos Cosmos\Packages. There will be a folder created for each asset.
Users will be allowed to change the storage folder through configuration and it is on our to-do lists. Thanks for the understanding and patience!Nikoleta Garkova | chaos.com
..and just as we speak, we've released information on How to configure the Cosmos Browser asset download directory (on Windows) We are currently working on publishing a documentation article on the matter but we don't want to keep you waiting.
When you start downloading Cosmos Assets, these will be saved to a default local directory: C:\Users\[User]\Documents\Chaos Cosmos\Packages
You can change this directory by editing the Cosmos Browser configuration file. To do so:- Go to C:\Program Files\Common Files\ChaosGroup\ChaosCosmos
- Open the file config.json with an Editor of your choice, could be Notepad as well
- Find the part: "working_dir":"C:\\Users\\[Your User]\\Documents\\Chaos Cosmos" and replace the path with the new desired directory, while preserving the syntax. Save the changes to config.json
- Restart the installed Cosmos Browser Service (CCBService).
To do so, in Windows go to Task Manager>Services. - When the service starts again, it will create two folders under the newly specified directory: Packages and Updates.
From this moment on, Cosmos assets will be downloaded to the newly created Packages
Note: Please note that Cosmos assets downloaded previously to the default directory C:\Users\[User]\Documents\Chaos Cosmos\Packages will remain hidden from the Cosmos Browser after the new directory configuration takes effect. So, you need to delete them.
Let us know if you encounter any problems. The final document will contain details for Mac users as well.
This has been further discussed in the Chaos Cosmos Wishlist section here.Last edited by nikoleta.garkova; 24-02-2021, 03:23 AM.Nikoleta Garkova | chaos.com
- Likes 1
Ok, I seem to have fixed it.
I manually uninstalled the cosmo browser using the .exe here:
C:\Program Files\Chaos Group\Chaos Cosmos\uninstall
Once I did that, I reinstalled the latest version of VRay and had to manually start the cbservice.exe here (it would not allow me to start/ restart in task manager):
From there, I followed the instructions and boom it worked.
I am now on build version: Build: 2021.2.15-183518
It seemed that my browser was outdated and that was the issue.
Hi theedge
Sorry to say that the Chaos Cosmos browser currently does not support any form of network install, including mapped drives, UNC paths, Google Drive/Dropbox/OneDrive. Support for network setup is on our to-do lists and we'll make sure to keep you updated on the matter.
