Volume lights
  • Volume lights
    Couldn't find a topic about this:
    Is VRay able to render standard type Max environment volume lights? I don't see my projector light beams anymore after switching from scanline to VRay.
    Thanks 'n' cheers,
    Metin
    Sevensheaven.nl — design | illustration | visualization | cartoons | animation
    Hi Metin,
    I seem to remember you need a free plugin called ScatterVL. I just did a search and found a few threads.
    Dan
    Dan Brew
      Metin,
      Volume lights will work, but they only seem to work with shadow map
      Needs more cowbell
        Thanks very much guys. I noticed that VRay shadows also don't work when using an other light that lights the scene with a projector map.
        Cheers,
        Metin
          And another tip: if you're using fog in your environment as well, as I do, be sure to set the atmospherics to the right order. The volume light suddenly appeared after exchanging its queue position with the fog atmospheric.
          Cheers,
          Metin
