No VRay lights in 1.47.03
  • No VRay lights in 1.47.03
    I just tried to put a vray light in a scene for the first time with 1.47.03 and they aren't in the Create panel or in the Create->Light pulldown. What could be wrong?
    Surreal Structures
    http://surrealstructures.com/blog
    Is strange.. Here is working fine... are located in the pulldown, under photometrics..
    Regards,
    Marco
    Workstation Core i7 6900 - 32GB RAM - GeF970
    Dual Xeon E5-2630 - 32GB RAM
      I got the vraylight ...under the pulldown are 3 groups Standard, Photometric and Vray.
      show me the money!!
        why do VRay lights need thier own pulldown group? bit anoying IMO
          Shortcut key?
          Eric Boer
          Dev
            Thanks. They aren't there, though if I merge one from another scene, I can edit it just fine. Maybe my menu file is corrupt.
            I didn't install 1.47.03 over my 1.0903. I copied the file tree over and made all the changes as advised here for dual installation. Maybe I missed an entry in the ini file (though I used Search and Replace for the changes).
            Surreal Structures
              nice one
                nice one
                So you really have nothing to contribute to this thread?
                Surreal Structures
                  Have you try to reload interface? Have you also try to custom your interface?
                  Regards
                  Laurent
                    Check your plugin.ini file, You'll need the paths to point to your new folder structure.
                    Eric Boer
                    Dev
                      The VRayLight should be in its own VRay category in the Lights part of the create panel. The reason it was moved is because the 3dsmax SDK does not recommend adding plugins to the default 3dsmax categories.
                        Thanks Vlado. I didn't know it would have its own catagory. All is well again.
                        Surreal Structures
