Remove VRay Warning message when loading old scene
  • Remove VRay Warning message when loading old scene
    I'm running a batch script on a lot of max files for different stuff, but can't let it run for hours because of old Vray3 scenes which popup this window:
Name:	Annotation 2021-05-18 142945.jpg
    I've check startup script but didn't find anything.
    How can I remove it, and put in a maxscript a way to actually convert (clicking yes) before saving so I have no more VRay3 scenes ?
    Regards
    Hello,
    If you want to press the yes button - here's a solution: https://forums.chaosgroup.com/forum/...081#post785081
    (you will have to translate the "Yes" string).
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Thanks,
      Indeed I tried set quiet mode etc, and finally run an autoit script aside that check for the window and click the button.
