VFB Vray5: How to get the Frame Number automatically noted?
  • VFB Vray5: How to get the Frame Number automatically noted?
    Hello,
    in the past there has been a postage stamp in VFB, is there something with Vray5, too?
    I need always to know, which frame of a sequence was rendered.
    Also the picture information (available for saved pictures in the history by right button click) which has a vast list, writes only 0000 as current frame number, which is not true.
    Thanks
    You can turn on the stamp in the vfb layers panel
      Thanks, but there is the frame also only always 00000
      (I had rendered frame 260)
      Please see attached screenshot
Name:	frame 00000.png
        What you need to do is to click on that line and then click on 'Insert Variable'...that puts that entry on to the stamp, so the same process for each data that you need added.
Name:	frame number.png
ID:	1135454Click image for larger version
Name:	insert variable.png
            As you can see, still it tells only 00000 - which is my problem all the time
              Ah, I see what it is. You are using GPU and I get the same, so apparently it's broken
              Maybe worth making a post in the GPU issues section.
                I was only testing once GPU, I’m normally always using CPU. But I’m sure it‘s the same with standard CPU rendering.
                But I will check today and post in the issues section.
                  No with CPU not working, too!
                    Weird...it works for me with cpu 5.20.02 build 00001
                      I have the same build, with current 3dsMax 2022.
                      Not working.... working currently with Phoenix FD renders
Name:	2022-01-02 14_23_40-Render Setup_ V-Ray 5, update 2.2.png
                        As mentioned in the other thread you started on this subject, please try the latest nightly, as it works just fine for me (with CPU).
                        Lele
                        emanuele.lecchi@chaos.com
                        Disclaimer:
                          Where do I get those nightlies? I can't see them in the download list...
                          (I have only installed the latest download)
                          Thanks
                            https://nightlies.chaos.com/main#/vr...ble/stable_5.2
                            Lele
                            Disclaimer:
                            • #15
                              Thanks, but where is the download?
                              There are empty folders, nothing visible or happening when I press on the buttons or "latest builds" or the date...
Name:	2022-01-03 11_19_04-Nightlies.png
