I have a question about Exposure Control
  • I have a question about Exposure Control
    you know, the sun is extreme overbright , we need to setup a ‘Vray Physical Camera’ or 'Vray Exposure Control' for tonemapping,
    Are them same in default case? why Exposure control has a little blue in white balance color?
    Hi could you give us a specific example, best with a scene?
    You can setup exposure control in your VRayPhysicalCamera or in 3ds max's environment rollout (rendering->environment).
    Please give us and example of that difference you are talking about.
    Vladimir Krastev | chaos.com
      There is no need to have an exposure control effect if you use a V-Ray physical camera.
      The effect is able to override multiple cameras at once, and sports its own white balance controls, but each camera can expose independently if the effect isn't present.
      If the effect's WB controls were set to a warm colour, you'd get a cold cast over the scene.
      Set it to D65 for sRGB standard whites (it's its default.), or remove it entirely to have a per-camera setup.
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
        Its just a empty scene , I use default Vray Exposure control settings , It come with D65 but the white balance little blue ( made rendered image warmer ) ,
        As you say, after click the D56 in list, the WB turned standard white...
        -- I often like to use this in a vray-sun/sky scenes, it dons't needs any physical cam while IPR .
          Ah, that looks like a bug (VMAX-8466).
          Thanks for the report!
          Lele
          Disclaimer:
            great !
            Expecting next update !
