VRayBlend and Displacement
  • VRayBlend and Displacement
    Hi
    I have a VrayBlend material where one of the coat materials has a displacement map in it.
    The textures inside that materials use Map Channel 3
    On the mesh, I have a UV Map, using channel 3, and a certain size, which I aligned where I wanted it
    Then I have a DisplacementMod, also set to texture channel 3.
    What I need to do is to make the displacement build downwards from the surface. Right now, it builds upwards. Can this be done?
    Kindly,
    Haider
    Using a minus value in the 'amount' should do it
      Hi! Unfortunately not
Name:	Negative value.jpg
      Kindly,
      Haider
        if you like, take a look at the max-file.
        Its all set up, just press render so you see the starting point. Then you can see if this is solvable.
        The base marterial can be swapped out to anything. I used Grass A from the Vray Material Library
        Kindly,
        Haider
          I guess this is what you want....
          You had displacement going in the shader too, so it was messing it up a bit, so just unlink that.
          I've inverted the displacement map which was the main issue apart from that.
