Is there a way to disregard refraction when calculating denoise?
  • Is there a way to disregard refraction when calculating denoise?
    asking for a friend....
    Not directly, but you can mask the VRayDenoise AOV in post by setting mattes for the refractive objects.
      mask AOV in post by setting mattes? do tell.
        i masked it manually for the time being in post using mat id..... interested in learning more about this aov character.
          Reason I ask is because I'm trying to solve multiple light sources through a heavy dialectric (low e glass)
          On a volume shell quick render/draft for review we noticed some lag in the refraction when denoising.... diffuse, reflect, spec clean hella quick, but the refractive lags and seems to pull a lot of weight if that makes any sense....
            HI you can try using the standalone denoiser tool
            https://docs.chaos.com/display/VMAX/Denoiser+Tool
            With it you can denoise render elements of your choice and then use in post production.
            Click image for larger version  Name:	explorer_2022-05-19_15-12-50.jpg Views:	0 Size:	91.7 KB ID:	1148531
            You will have to set your VRayDenoiser to only generate render elements so no denoising will happen unless you do it manually with the standalone denoiser tool.
            Vladimir Krastev | chaos.com
              Since the original RGB (non-denoised) is usually saved together with the VRayDenoiser element (or/and effectsResult), you can create mask for the refractive objects (with a i.e. MultiMatte/Cryptomatte/etc.) with which to mask out the denoised refraction (the underlying layer should be the original RGB). The method vladimir mentioned is also adequate - you can comp the RGB with the non-denoised VRayRefraction.
                Thank you both for explaining that! : )
