Lens effects only on illuminated materials
  • Lens effects only on illuminated materials
    I am trying to render an illuminated dashpanel using VrayBlendMtl.
    Base material is black with coat materials with different VrayLightMtl using masks. Now I would like to lit all the different lights together with some Framebuffer Lens effects. Unfortunately everything (incl. white text decals) is used by the Lens effect.
    How can I isolate only the illuminated parts which are using the VrayLightMtl?
    3dsMax 2024 | Vray 6 (Update 2) | AMD 5950X | 128GB | RTX 4090 | Windows 11 Pro
    Hi could you explain a bit further you workflow? Please include a few screen grabs of your VFB and material editor.
    Vladimir Krastev | chaos.com
      You can do this by adjusting the 'threshold' parameter.
      So for example, look at the pixel value of the light material and if it is e.g 10 then set the threshold to maybe 9.
      That will likely be higher than the value of all the other objects that do not need the lens effect.
        Thks fixeighted, I will give it a try!
          Hi, how can I check the value with V-Ray 6?
          Jackie Teh
          3ds Max 2023, V-Ray 7 Update 1 [7.10.00 build 00000]
          AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
          Website: https://www.sporadicstudio.com
          Email: info@sporadicstudio.com
          YouTube: https://www.youtube.com/c/SporadicStudio
            Just hover the cursor over the vfb and check the values at the bottom left
              The HSV or web or 8 bit?
              Jackie Teh
                The rgb ones
                  RGB= 8 bit? got 3 value, choose the higher one?
                  Jackie Teh
                    It's just so you can see what the highest value is, so you can adjust the threshold.
                    So e.g. if you have 2 objects and you want only one to glare, if one object's highest pixel value in any rgb is less than the threshold value then
                    you adjust the second object's value to be generally higher, or adjust the values of the other object to be lower than that threshold...whichever works in the situation.
                      Thank you for your guide, will give a try.
                      Just give it a try, but I have no luck, all the 8 bit rgb value is 255, so I put 255 in the lens effect threshold, but no luck
                      PS:
                      Finally, I figured it out and the get result I want, thank you very much.
                      Jackie Teh
                        You need to look at the RAW values not the other ones.
                        A.
                        www.digitaltwins.be
                          Yes, that's what I have figured out, thank you
                          Jackie Teh
                            I'm set to RAW as default so I always get the correct readout, but it shouldn't really matter as it's only a comparison, unless I misunderstood what you wanted to do ofc
                            • #15
                              Thank you for your sharing too.
                              Jackie Teh
