LensEffects and RGB WITHOUT LensEffects in Same Render?
  • LensEffects and RGB WITHOUT LensEffects in Same Render?
    Is there a way to render and animation and get VRay to save out the LensEffects Glare channel, as well as the RGB WITHOUT LensEffects applied? So I have the lens effects by itself to apply in post...
    I never seem to be able to make this happen. There has to be a way short of rendering twice, right?
    There must be a better way i am not aware of, but in the while you ought to be able to get it done by adding a light select at defaults (i.e. "Full" mode.), with the include/exclude mode set to exclude.
    The list being empty, it will include all that's lit, and won't be touched by the lens effects.
    See attached.
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      Creative. Thanks.
        Originally posted by Joelaff View Post
        Creative. Thanks.
        While Lele's workaround is indeed working, there is a simpler solution already available: In the Lens Effects settings, enable "Save Glare channel" as well as "create effectsResult channel". This will give you the following output (no matter if saved manually via VFB or automatically):
        - RGB_Color with Lens Effects baked in
        - origRGB without Lens Effects baked in
        - and the Glare channel with Lens Effects only
        By combining the last two, you can recreate the RGB_Color.
        However, there still is a caveat to that: Depending on how you save, the channels are named differently. I still consider this as a bug. Don't know if this is still a thing in 6, in 5 it definately is:
        https://forums.chaos.com/forum/v-ray...es-when-saving
          ah-ah! Indeed, that's when it shows up, on save.
          Nice find Olli, thanks for that!
          Lele
          Disclaimer:
            I am happy that Chaos still listens to it's users (well, most of the time ) because it was still a request a few months ago. If the discrepancies could also be fixed in the future, that would be great. Maybe they already are, I did not check in 6 yet.
              with VRayLightSelect remember about adding VRaySelfillumination as it is not included.
              Marcin Piotrowski
              youtube
              CGI OCIO config 04
