Render is completely different when using VFB compared to when not.
  • Render is completely different when using VFB compared to when not.
    When I'm using the Frame Buffer, my render looks like this:
    (Ignore the noise, super quick render)
    then when I turn off "Enable built-in frame buffer" in the render settings under "V-Ray", it turns to this:
    It's basically pitch black, why aren't they the same?
    Hi with just these two screengrabs it is impossible to tell for sure. I place my bet on exposure correction in the VFB. Here is a bit of info about it - https://docs.chaos.com/display/VMAX/VFB+Settings
    We will need a bit more info - at least widen the screengrab a little so it is visible if you have additional active layers in the VFB or if you have changed your display correction.
    Vladimir Krastev | chaos.com
