Evening,
i'm having a lot of trouble with lightcache since I updated to vray 1.47.03,
first every object returning overbright color (see another thread in this section) and now, something I would have really liked to avoid, here are the facts :
I'm making an animation for tv, 16:9 format pal, 1024*576, all my camera pathes are made,I follow Vlado flythrough turotial, when making the lightcache flythrough calculation, max keeps crashing somewhere around 75% ofthe calculation process when subd are high,
500 gives me no crash, above 1000 makes max crash (stupid windows error "max encountered a problem and will now shutdown")
Subd 2500 // fixed, world, prefilter 10, sample size .02cm
Is what makes max crashes
Same but with subd 1100 is ok...
Memory problem ? Running a p4 3.4HT with 2gig of ram on board.
Thanks for info in advance as deadline is, well hum bouh
friday
best regards,
chris
*edit* calculating with half resolution gives the exactly same problem...
btw using that /3GB switch, couldthat cause the error ?
thank you
best regards,
chris
thank you
