HDRI Background showing up in glas material
  • HDRI Background showing up in glas material
    Hello, i just have i problem with my background and glas. It shows up in renderings, but should not be there. In the scene i use a dome light and made the background invisible.
    I think its a problem with glas material?
Name:	Screenshot 2023-04-03 152943.png
    Hi, thanks or posting. Are you using VRayDome light with hdri texture? If you are, enabling "invisible" for the dome light will not remove the hdri from reflections/refractions.
    If you want something different than the hdri texture in your reflections/refractions, use the V-Ray Environment overrides.
    Vladimir Krastev | chaos.com
      Hello Vladimir, i tested it with invisible option in the domelight settings. It shows up too, if i turn of the environment in 3DS Max the glas is rendering in black.
        Hi, the invisible option in the dome light does not remove it from the reflections/refractions. If you want to see something different than the dome light's texture in your windows you have to use the V-Ray Environment
