When is the...
  • When is the...
    Vray converter going to be able to convert corona physical materials to Vraymtls? This is a option needed yesterday.
    It's been doing that for a few months already.
    There are important caveats on the maps, but the conversion of the shader is a done deal (save for bugs.).
    If you have a scene that's being problematic, please send it over to support so we can check it.
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      It has?...I ran a conversation then other day and it converted the bitmaps but it kept the corona physical map node. I had to create a vraymtl node and attach the vraybitmaps to it and assign it to the object. Maybe I'm doing something wrong.
        Any scene would help us figure it out.
        Lele
        Disclaimer:
          Sure...Where do I upload file to? And do I need to archive it?
            There is a link to support from within Max itself in the help menu.
            Alternatively, upload the file wherever you please/feel comfortable with, and mail/PM me the link.
            I don't think we need the textures, so the base max file with the shaders and maps should do.
            Lele
            Disclaimer:
              Also noticed that vraybitmaps are set to inverse gamma vs. Auto. Is this correct?
                Here ya go.
                  It requires a login, that i can see.
                  Lele
                  Disclaimer:
                    Try This:
                      This worked, thank you.
                      Could i ask you what version of Max was this done in/you were having troubles in?
                      Lele
                      Disclaimer:
                        Right, so it would seem those leftover corona Physical materials aren't assigned to anything, but the converter doesn't delete them because they are in a slate view.
                        They should be safe to wipe.
                        Lele
                        Disclaimer:
                          2023 25.0 - 25.0.0997
                            What about the inverse gama issue on vraybitmaps?
                              The bitmaps do it right, yes.
                              IT's forced to be explicit, so that you know that we have not changed, f.e., the gamma on a data texture you can't see directly.
                              Lele
                              Disclaimer:
