Vlado's Article on Intel's Open PGL in V-Ray
  • Vlado's Article on Intel's Open PGL in V-Ray
    For those with a knack fopr technical stuff, another article has emerged from the Innovation Lab's valuts, this time penned by Vlado himself, with the help of the Intel researchers behind the library.
    https://www.chaos.com/blog/path-guid...n-pgl-in-v-ray
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
    Any plan to add this (even in beta) for Vray GPU, or it is completely irrelevant for this architecture ?
    Thanks,
    Nicolas
      Thanks,
      Nicolas
      from here:
      Note: support for different GPU backends is planned in future releases.
      Lele
      Disclaimer:
        Very interesting, I’ve tested this as soon as it was available for C4D a few days ago. I’ve got about 30% speed up for an interior but it looks like increasing the LC sub can speed up things even more, will test again in the afternoon!
        3D Scenes, Shaders and Courses for V-ray and Corona
        NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
        @3drenderandbeyond on social media @3DRnB Twitter
          This seems to me to be similar to Metropolis Light Transport, whereby paths that "found" a light source were able to explore nearby paths. Is this different?
          Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
          www.robertslimbrick.com
          Cache nothing. Brute force everything.
            This is more of an alternative to Metropolis, as they share the same goal (scene exploration to find light sources, more efficiently than basic MonteCarlo tracing could.) but achieve it in a different way.
            This is designed to be combined with MC, it's currently unknown if it could be combine with MLT.
            Lele
            Disclaimer:
              Tested again increasing LC from 1000 to 3000 subdivisions, I’ve got a speed up from 30% to 45%, so compared to the original scene with no PG it renders almost twice as fast.
                If you have a domelight, is it set to Adaptive?
                Lele
                Disclaimer:
                  No dome light, only a physical sun/sky and several area, spherical and mesh lights.
                    Oh, that's why, perhaps, you had such huge increments.
                    The Adaptive Domelight should provide for speedups by itself (it's where we put the sky map in Max).
                    Without the Adaptive dome, finding the sky is hard, unless in C4D the importance sampling, and adaptive dome tech are both embedded somewhere else.
                    Lele
                    Disclaimer:
