Memory Allocation Failure
  • Memory Allocation Failure
    Just tried to render some glass from that render of mine ages ago. But there were 36 glasses, all turbo smoothed at rendertime.
    Now I am assuming this error is just a general running out of memory error, but seemed abit odd and i havnt seen it before so though i might post it here to see if anyone else has experienced it before.
    Max itself didnt crash but the render obviously couldnt proceed.
    Simple scene 2 vray lights a couple of cameras and the cups.
    could you maybe share the scene? what version of max is it?
      I can share the scene if you want.
      3dsmax7
      Vray 1.47.03
      I am fairly certain that the problem could be solved with vray proxies or lower Turbosmooth level but seeing as i havnt see this error before or on this forum thought i would ask around.
      Will upload the file now and PM you the link.
        Actually I just lowered the turbosmooth by one level and it rendered fine in 14m10s. So it was definitly just a running out of memory error just one that I havnt seen before.
        It renders fine with 2million faces but it couldnt quite cope with the 8million faces at the next level of turbosmooth...odd error tho.
        What are the most common ways of rendering this many polys? Are vray proxies the only option? I would like to test out some options.
        If you like I can still upload the file for you to have a look at, just let me know.
          no i suppose its not necessary. just thought it might be a way to see if anyone else could render it. I dont have max 7 though...
            i think in an instance where you need heavy smoothness on multiple objects which forces your computer to runout of memory vrayDisplacement mod with sudivision setting could come in handy.
            Dmitry Vinnik
            Silhouette Images Inc.
            ShowReel:
              percydaman:
              Ah ok, well as you can see I got it to render anyway, just without as higher Turbosmooth as i originally had, probably doesnt even need that high. Now im just try to see if I can find a way to make it render the scene with atleast 8 million polys
              Morbid Angel:
              Good idea I will give that a shot, wonder if i can get it to render 8million polys without crashing
                are all of the glasses instanced?
                Chris Jackson
                Shiftmedia
                www.shiftmedia.sydney
                  i think if you are dealing with high million count then vrayProxy is best. All tho I never used it. But I heard it works well.
                  Dmitry Vinnik
                  ShowReel:
                    jacksc02:
                    Initially they were copies, then I instanced them.
                    Morbid Angel:
                    Yeah i figured vray proxy would be best. Gonna try that now.
                      Ok, after proxying 1 glass that had been turbosmooth at the higher level and collapsed to editable poly, I was able to render out 36 glasses and i assume it had the same number of polys as previous just before it crash so it was just over 8.1million polys
                      Memory usage according to task manager was a mere 462mb for Physical and 515mb for Virtual.
                      Render time 22mins.
                        You could also enable the /3GB to allow 3dsmax reach a vm bigger than 1.6-1.7 Gb. We have a current work in progress that has lots and lots details, and is about 25-30 Million polys and renders ok with a mix o vrayproxies and non vrayproxies, and memory usage is about 2.2 in virtual memory for max.
                        Daniel Santana | Co-Founder / Technical Director
                        You can do it! VFX
                        Lisbon/Porto - Portugal
                        http://www.ycdivfx.com
                          I could look this up but im feeling lazy... hehe so i will just ask.
                          Does the 3gb switch work with windows2000?
                            no, only winxp. winxp64 bit has it built in.
                            Dmitry Vinnik
                            ShowReel:
                            • #15
                              Mmm after a little digging it may be possible according to this page
                              http://www.microsoft.com/whdc/system...AE/PAEmem.mspx
                              Meh im gonna install winxp on my raid0 setup once I get it.. LOL
