Node
  • Node
    I have an upgraded laptop and a new desktop. I am pretty sure with my premium license I get a render node, correct? Is it an extra render node, or is the render node needed to render anything? V-Ray once came with 5 render nodes, so I am assuming it is an actual extra render node and I can network my laptop in. I don’t have a network, so I am assuming I can just patch a CAT6 between my desktop and laptop, correct? It has been a decade since I did any network rendering.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Okay, so by the looks of it, the node that comes with the V-Ray license is needed to render on one machine. So, V-Ray went from 5 nodes to 0?
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      You need the rendernode from your subscription to render (with VRay) or change (VRay) materials when working in 3dsmax. So if you want to render on your laptop you can't do these things inside 3dsMax on your working PC. You can check your licensing in your account to see what is going on.
        Basically, you can't render without a node, so without a node, V-Ray is bricked. You have to buy a node for each machine you want to render on?
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Here is my license situation. I am not sure what the NEXT render nodes can do for me? It also shows a V-Ray 5 render node, so is that an extra one? This should probably be in the license section of the forum.
Name:	Screenshot 2023-08-28 115824.png
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            You should look in your owned products section, where the V5 en VNext nodes are coming from and if they are perpetual (licensed to infinity). Did you upgrade some of the 10 perpetual VRay3 nodes in the past?
              I have some perpetual seats from a Choas "Partner", so I guess I have to contact them. I also have a V-Ray 5 for 3ds Max - Perpetual, again from a Choas "Partner". I don't think I upgraded to the latest V-Ray, I purchased a new license. I emailed support, but I fear that I'll be waiting a month for a reply.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                I still have 10 perpetual VRay3 nodes which I could upgrade to Vray6 nodes. But I don't think I will ever need nodes again because there are better and faster tools to handle renders on single workstations. But if I did, I certainly would go the subscription route! So nothing lost.
                  Yes, when Chaos stripped the extra nodes from V-Ray, I purhcased a computer with 36 cores to avoid having to buy the extra nodes.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Curious how you are rendering? is it not inside 3ds max ui? if it's outside of 3ds max ui, likely you need that node.
                    Dmitry Vinnik
                    Silhouette Images Inc.
                    ShowReel:
                      No, it is inside MAX - I am sure I need another node. It is strange pricing... $190 for a year, or $75 monthly.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        This shouldn't be the case, unless I misunderstand something. You have the gui license? it should let you render in the ui interface. What cpu did you end up buying?
                        Dmitry Vinnik
                        ShowReel:
                          Okay, I render on my main PC now and I want to use my laptop as a slave. I can purchase an annual node license for $190, but if I wanted to do it monthly, it is $75 per month.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Looks like you have a vray next render node, you can upgrade it to vray 6 render node, if you follow this link. Should be about $300 (I'm not sure if its annual though)
                            https://www.chaos.com/upgrade/render-node
                            Dmitry Vinnik
                            ShowReel:
                            • #15
                              Yeah, something is strange. I can buy an annaul for $190, without an upgrade. Also, I purchased it from a 3rd party and they are not getting back to me.
Name:	Screenshot 2023-08-28 181553.png
ID:	1189455 Click image for larger version
Name:	Screenshot 2023-08-28 181545.png
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
