Best way to convert Autodesk Generic Materials
  • Best way to convert Autodesk Generic Materials
    Just curious if what I did was the best way.
    Used Max's converter to make Autodesk Generic into Physical Material.
    Then used VRay scene converter Physical Material to VRayMtl.
    Since there are a lot of different ways to convert is there a better method?
    I use V-RayMax Converter Pro, which can convert both Autodesk Generic and Physical Material directly to VRayMtl without any intermediate steps.
      Yep, the V-RayMAX Converter is the way to go!
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090
      • ​Windows 11 Pro
        Thank you for the replies I will look into it.
        Just out of curiosity what specifically does this tool do better in this instance?
          It simply works.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
