Smooth
  • Smooth
    I have the geometry, and it isn't smooth. Applying a smooth modifier destroys the geometry. How can I fix this?
Name:	Screenshot 2023-11-03 194744.png
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    It is an SU import walls.rar
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      I think that a small threshold is working.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        You can also manually select all the polys on the curve and put them in the same smoothing group manually in Edit Poly.
        https://help.autodesk.com/view/3DSMA...E-01B90F7EB320
          Either a vertex weld or a Editnormal > reset normal, should fix SU geometry.
          A.
          www.digitaltwins.be
            if you export that as an obj, it has a warning you have a rats nest, (Overlapping faces or vertices​) some nasty geo..
            e: info@adriandenne.com
            w: www.adriandenne.com
              I imported the SU into MAX. I think I go it as a SKP
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                glorybound I think that this is a good suggestion. Have you already tried it?
