Batch Render Preset for Frame Buffer Layers not working
  • Batch Render Preset for Frame Buffer Layers not working
    I've saved a .vfbl file for layers but can't seem to get it to stick for Batch Rendering. I created a Preset, thinking that either "Environment" or V-Ray GPU 6 Update 1.2" Categories would capture the frame buffer data, but apparently not. Any ideas for how to make this happen? Thanks.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    What do you mean by this? .vfbl presets are loaded in the VFB itself. Could you describe your methodology so I can better understand what's going on?
      I think I found the answer in this thread and it's not possible what I'm hoping to do.
      Basically, I wish to use batch render and scene states for a series of different camera/light setups for a scene. But I am using VFB for compositing on output. The goal is to have zero post-work (done all in VFB). However, in the batch render process, I notice that each time VFB runs at the 'default' Lightmix setting so I have to be watching in order to load the .vfbl preset for it.
      The thought was that I could make a V-Ray render preset and then load that into the batch render and all would be right with the world. But I guess not. If only there was a way to add VFB as a "state" or preset or something...
      Does this help?
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        I see. You could render the images, re-load them in VFB, apply the desired preset, and re-save again. The VFB has a "Batch image processing" function (VFB>File>Batch image processing) to speed up the process.
          Yes, That is our workflow for larger interior environments, but for smaller object renders, it's a pain since there are so many. Oh well... maybe someday! Thanks for the reply!
          David Anderson
          Software:
          Windows 10 Pro
          Hardware:
          Puget Systems
          TRX40 EATX
          128GB RAM
            Look into a scene manager like Pulze Scene Manager (RPM, Reindeer, RenderStacks, etc) or similar. Saves you a couple of weeks work in a year. I know Pulze Scene Manager can do this no sweat.
            A.
            www.digitaltwins.be
              To be clear, Scene Manager and not Render Manager would let me do this?
              Thanks!
              David Anderson
              Software:
              Windows 10 Pro
              Hardware:
              Puget Systems
              TRX40 EATX
              128GB RAM
                You can define any .VFBL per scene you render yes. I suggest you give the trial a try.
                A.
                www.digitaltwins.be
                  It's interesting that I can follow the directions, but when I use the Pulze batch render, the Post-Production settings are consistently ignored. I'm starting to think that it doesn't do what I need it to.
ID:	1196596Click image for larger version
                  David Anderson
                  Software:
                  Windows 10 Pro
                  Hardware:
                  Puget Systems
                  TRX40 EATX
                  128GB RAM
                    Pulze scares me because it says it requires a constant internet connection. I can’t have a tool that may leave me high a dry on a project if their server goes down or our primary and backup internet connections go down.
                    I need to test it with an Internet outage and see what happens, but that seems like a totally unnecessary requirement serving only the needs of the developer, not the user.
                      Just tested this, if you want a different VFBL per scene, then it works as intended. When I change scenes I can see the VFBL layers and settings change. Maybe you're using it wrong? It's a bit tricky sometimes if you don't know how SM works yet.
                      A.
                      www.digitaltwins.be
