Object with self illumination behind glass
  • Object with self illumination behind glass
    Is there a way to change in VBF the multiplier and the color of vrayselfillumination RE behind glass? (without the need to use ligtmix RE).
    I try and it doesn't work for me​
    HI, thanks for posting.
    I don't think there is but I will look into this in a bit more details and get back to the thread.
    Vladimir Krastev | chaos.com
      Set the glass refraction to affect all channels.
      Click image for larger version  Name:	image.png Views:	0 Size:	1.37 MB ID:	1202244
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
        Thanks LeLe
        It works as you suggested but the glass becomes brighter
        See attachment (I did not change the the selfilumination)​
          and another question.
          What are the disadvantages of using for glass the option of effect all Chanels and color+alpha?
          Thanks​
            Originally posted by roysgi View Post
            Thanks LeLe
            EDIT: this is due to the glass refractionn being doubled up. Deactivate the refraction RE in the B2B composite.
            There are no significant ones from a computational standpoint.
            What changes is that the parts seen behind refraction will not end up in the refraction RE alone, but will go where they should, with affect all.
            F.e. selfIllumination, or an mask.
            With color+alpha, the refraction will make the alpha of the image as black as required, instead of leaving it solid white.
            Both modes are optional due to varied workflows.
            Lele
            Disclaimer:
