Apply modifier on only one face...
  • Apply modifier on only one face...
    Hi Guys ! Good friday to all !
    Is someone could explain to me, step by step how to apply any modifier on only one face of a cube or something else ?
    I will greatly appreciate ! Thanks in advance !
    The Poly Select modifier should do the trick. Note that the object must be an Editable Poly. Basically, add Poly Select, select faces/edges/vertex/elements, and while the selection is active add another modifier to affect only the selected parts.
      It was an "Editable Mesh", I convert it to an "Editable Poly"...
      But ! I dont know why, the "Vraydisplacemod" is applied to all the object...
        Like this...
ID:	1202257Click image for larger version
          In this case, that method won't work. However, activating the "Use object mtl" in the VRayDisplacement options and using a Multi/Sub-Object shader, where only a certain ID has a displacement map plugged will work. Check the attached scene.
            Thank you very much !
