Hi everyone. I'm just curious to know what you think about V-Ray Tiles. This could be an inhouse map that could replace Bercon Tiles. What do you currently use? What do you think could be improved in your current workflow?
That would be great. Bercontiles, is too fumbly and I can't get it to work properly with certain things. A native chaos tile map that can have tiles that work with multisubtex (random texture per tile), triplanar and uvwrandomizer (if for instance you only have one map and you want to rotate, scale, move the map per tile), out of the box, would be a nice to have. Also would be nice to work with 2D displacement.
I think its a perfect idea, I love BerconTiles, but in some rare cases it causes crashes, I have tried CoronaTiles and its a good implement, simple and ready to use, something that would be interesting is to have a map similar to BerconGradient, with this map you can make interesting variations for each tile in color and displacement channels.
What I like about having Corona installed is that many of the Corona Maps are 100% compatible with V-Ray, but having a V-Ray option would be necesary to use those maps (I use alot Corona ColorCorrect, Front/Back, Corona Select) when exported to other platforms like Vantage.
Would love to see this. Working with 2D displacement as mentioned above. I use Bercon extensively and would like to finally replace this with a native Vray map.
A great tile maker would be fab, just try bercon with displacement, bercon joints are poor as well, next to useless for closeups. A Vray tile generator supported across their platforms would be a massive bonus.
Can you name some downsides you would like to avoid by using V-Ray tiles?
I don't really have specifics other than for one, an in house version would be kept up to date with each V-Ray release while BerconMaps lags behind a bit. Also, native compatibility with V-Ray means better integration with all functions. I can't remember exactly, but I feel like I ran into issues with BerconMaps while trying to render with GPU.
Yes please. We use bercon a lot but a native version would be great. One request would be able to do a herringbone pattern that isnt fixed to a 2x1 tile size, which is a limit in bercon.
Features we use currently are:
- randomisation of submaps (multimap)
- randomisation of tile placement (mirror, rotate)
- creating a pattern based on a different map that blurs the bercon into individually coloured tiles. The one in the general bercon tutorial.
- we use a blend of bercontile with noise maps to create messy grouting for paving. Maybe an inbuilt option would be nice.
