Script to change VFoV
  • Script to change VFoV
    Is it possible to change the Vertical Field of View setting in the camera dropdown of the render settings (spherical cam) using MaxScript?
    I tried showproperties vr to see if I could spot it but it gives me an error.
    To be clear, are you entering "showproperties vr" in the listener or "vr=renderers.current; showproperties vr"? "vr" is only a variable in this case defined to be "renderers.current" or "V_Ray...." It's essentially like entering "showproperties renderers.current" but allows you to use the "vr to set the options later.
    With vr set, the script is vr.camera_fov=###. ​​
      Thanks for the info, I understand now. I was entering "showproperties vr" in the listener.
      I have vr.camera_fov=### working and can use vr.camera_overrideFOV=boolean to toggle it on and off, but I can't see the setting to change the vertical field of view. Does this exist?
        Scratch that, I've found it. It's the option camera_cyl_height= ### as it changes to 'vertical field of view' when spherical panorama is set.
