global multiplier for displacement modifier edge length
  • global multiplier for displacement modifier edge length
    im not sure if this is a feature request, or if anyone knows a script?
    ive got load of objects in my scene with displacement, it was rendering fine, but bumping up to production resolution and i get a crash with the embree accelerator.
    i manually have to change all the edge lengths to something reasonable for the resolution.
    i use soublurn scripts to select all the objects with the modifier on, but i still have to change them all manually.
    any suggestions?
    Hi, thanks for posting. If you are using the displacement slot of your VRayMtl then you can control the displacement globally through here:
    If you are using multiple VRayDisplacementMod that are not instanced you may need a script to go trough all of them.
    Vladimir Krastev | chaos.com
      hi, thanks for the reply, im not using the displacement slot, a lot of these are imported megascans assets which automatically apply the displacement modifier. I also find the modifier gives more control, so it is always my preference.
      any tips on a suitable script would be most appreciated.
      please not i dont wish to set a single edge length for everything, thats very inefficient as i have a large expanses of water and tarmac, that do not need fine subdivision and kill my pc if it has a short edge length... however i have smaller objects that really need extra detail.
      i wish to apply a multiplier to all the existing values.
        For mass changing anything ever in 3ds Max > Modifier modifier Zorb: Modifier Modifier Zorb | ScriptSpot
        A.
        www.digitaltwins.be
