Vray glare on selected object 3ds max
  • Vray glare on selected object 3ds max
    May I know how to apply glare to selected object?
    Jackie Teh
    3ds Max 2023, V-Ray 7 [7.00.05 build 32980]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    The lens effects are a post-process effect, based on the pixel value data of the image. There isn't a way to manually assign glare to specific objects (as in 3ds Max), unless, of course, you play around with i.e. the intensity of the light/self-illuminated object. Do share more about your current case and what you're trying to achieve.
    EDIT: Check post below. I totally forgot you could use a mask!
      Originally posted by jackieteh View Post
      The lens effect layer could be masked. The easiest way is to apply a Cryptommate mask by node name. Then with the picker select which of the objects you would like to be affected.
        EDIT: Check post below. I totally fogot you could use a mask!
        Thank you to the help from both of you.
        Jackie Teh
