Error: Building Embree Box Tree failed
  • Error: Building Embree Box Tree failed
    Just to start I've already gone through this post - https://forums.chaos.com/forum/v-ray...or#post1217584
    - I've reinstalled Vray
    - I've tried to install from C:\Program Files\Chaos\V-Ray\3ds Max 2024\utils but it says I have the latest version already.
    I have no displacement switched on either and it happens straight away so the RAM isn't the issue.
    Help on this would be great as we cannot work on our projects at the moment.
    Latest Vray and using MAX 2024.
    Thanks.
    So I found a solution for anyone else....
    Go into Add or Remove Programs> find everything thing that has Microsoft Visual C++​......and uninstall it. You can then install just the latest version Microsoft Visual C++
    https://www.autodesk.com/support/tec...Libraries.html.
    Hope this helps others.
