editable mesh question
  • editable mesh question
    I have buy and download a tree 3d model, the editable show like the image attached here, when render it look ok. is this normal?
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    What exactly do you mean?
      The tree trunk not display in mesh, it only display circle a line...is it normal? when render it look fine...
      Jackie Teh
        It's because it's a Growfx tree, so it'll render fine but is a pain if you wanted to edit the geometry for any reason. Try converting it to editable poly and you'll see that it is pretty messed up.
          I have converted it to editpoly, but cannot edit, can delete some part only. Is that anyway to make it as normal mesh, quad surface... so we can edit it easily?
          Jackie Teh
            I guess it depends on what you want to edit but what you can do is to detach the trunk and branches, apply a subdivide to clean up the circles nastiness, then retopologise that, giving you quads.
            You'd lose the mapping, so would have to deal with that but at least it be 'normal'.
              Thank you for your help, i will give it a try
              Jackie Teh
