Hi all
we have finished a long animation project and although our customer like it , i know it was to noisy.
there are 2 quicktime movies attached :
both of them we rendered the bed and floor on 1 layer and the room on a second layer and the comped them.
the room was rendered with pre calc irr map + lc and and it wasn't bad.
we rendered it with irr map + lc on single mode , look at all the noise and flickering especially where the mattress is near the construction of the bad.
www.3dvision.co.il/tests/ir-map.mov (right click and download it)
the settings for that movie are
I've tried a test render based on qmc + lc , i used the same lc settings and default settings for qmc. aa on this one was adaptive qmc 1,4.
www.3dvision.co.il/tests/qmc.mov
on this one it was more noise but a different kind of ...maybe a bit more steady.(it also turn out darker but that can be fixed by increasing the primary gi multilayer).
can someone please help me / us get a clean render without getting much higher render times.
would be nice to get chaos response to this and publish some kind of settings and method that is recommended by them.
those kind of noise and flickering is something you can only fight when you have time for a project , not on a tight deadline that you have to finish the render on weekend.
BTW time per frame was around 10 Min's on a x2 4200 1g node.
i hope this post will be informative for all of us.
Best regards
Gili
Best regards
Gili
