Skyscrapper Glass???
That glass done look anything special.. its mostly in the reflections.
I would suggest.
Black diffuse
White reflection (vary if needed)
fresnel ticked (also works very well in some cirumstances with it unticked.. then you need to lower the reflection alot)
white refraction
choose fog color to suit and lower fog multiplyer until you get a nice color.
But its still gonna look shit unless you have it reflecting something nice.
I believe those kind of glasses can be produced with some tweakings.
The fastest way is to use a MIRROR type material, then mask them and
in PS adjust all the rest (opacity, etc.)
But as DaForce said, it's all about that it would reflect.
A glass in a pitch-dark is hard to be seen, isn't it ?
nikki Candelero.:: FREE Your MINDs, LIVE Your IDEAS ::.
To really get the nice realistic skyscraper glass look, you need to remember that in real life, that glass is warped considerably. So I like to give the glass a slight bump map as follows. I render an ortho elevation with mullions flat black and glass flat white. Then I take it into PhotoShop and magic wand each pane of glass and separately give them a slight gray to black gradiant at all different directions. Then when all are done, I use a large fuzzy burn brush to dirty it up a bit. Lastly, I use levels to adjust the darks so that the black to gray variation is very subtle. I map this back onto the glass with a very slight bump map that warps the reflection just enought to make it look real. This sounds like it takes a long time but it goes really fast and the results are worth it.
Craig
Originally posted by CandeleroA glass in a pitch-dark is hard to be seen, isn't it ?They're right about the reflections though...
