VRay Fur
  • VRay Fur
    hi there,
    i'am on the way to make a little project, where have to be a spherical body with only a few hairs on it (like 10-20).
    i would like to use Vray Fur, but the sphere has over 90,000 faces and when i render it looks like a critter.
    i've tried to say him hairs per area: 0,00001
    the same by face. but nothing.
    i could use a second sphere with less polys at non renderble but is there another way to reach this?
    best regards
    jonas
    Jonas
    www.jonas-balzer.de
    www.shack.de
    maybe 1 per face with selected faces option?
    Eric Boer
    Dev
      all faces select? or select by hand?
      because like to have the random option
      Jonas
      www.jonas-balzer.de
      www.shack.de
        You may select which polys you prefer, then detach them as a separate object, and do the 1 per face option as RErender said.
        P.S.: Keep in mind that per face would create 2 hairs on a quad poly as there is a diagonal edge hidden.
        nikki Candelero
        .:: FREE Your MINDs, LIVE Your IDEAS ::.
          ok, thanks a lot for the tips, i'll give it a try,
          but i think its a point for the wishlist for me,
          - instanced geometry
          - total numbers of hairs.
          Jonas
          www.jonas-balzer.de
          www.shack.de
            I have to agree to this, had the same problem myself..
            I think maybe it is an scale issue. If you are using a coordinate system that makes your scene very small compared to the internal vray system, your fur will be very dense..
            -Tom
              hi winberg,
              is there an internal scale in VRay?
              doesn't he adjust it to the scene scale?
              Jonas
              www.jonas-balzer.de
              www.shack.de
                vray usually uses max' system units as its own basic units
