VraySun / VraySky Animatable?
  • VraySun / VraySky Animatable?
    Is the VraySun / VraySky system animatable?
    i.e. could you simulate the sun moving from midday, through to dusk and through to night, in the same quick way you can animate the standard Max Sun moving according to time of day - but obviously using the VraySun / VraySky system it should analytically change the colour of the sky and amount of lighting etc?
    Yes
      nice.
        you can make max daylight system turn it off, link vray sun to it, animate max sunsystem and that should do the trick. Vray sky will animate automaticly to the sun.
        Dmitry Vinnik
        Silhouette Images Inc.
        ShowReel:
          we've been asked to do a 15 second animation in the style of time lapse photography, with the sun moving from day through to night, but also with "weather" zooming in and out.
          I'm doing a lot of research into how to achieve this, but how would you say is the best way to achieve this in the most believeable way?
            Here is one I did a bit ago testing the new sun/sky:
            http://www.redeyetales.com/forum/Vray/Sunset.mov
            Is that what you are looking for?
              nice one chris, how long were the render times for this? a see a bit noise flickering...
              Dmitry Vinnik
              ShowReel:
                yep thats exactly what i'm going to need to achieve, but it's an external shot and i'll probably need to show some weather clouds also.
                That's really nice - your colours are absoluetly spot on, really strong during midday and really nice and subtle in the evening. Supurb work Chris.
                  Noise is actually a lot less in the raw frames. That compressor sucked. But there is slight noise. I think it is bit from the GI, but also from the AA, and the DOF effect. I sorta went nuts and have it all... brute force QMC GI, DOF, etc... on my now old dual AMD 2600+ took around 40 min to a hour a frame. Based on the benchmark thread, a new computer should do that 6 times faster.... so 6 to 10 min a frame is my guess. Oh yeah... this is also with the physical camera... IMHO, the sun/sky is nothing compared to how impressive the physical camera will be.
                    Anything out of NDA that can be said about it?
                    Even with a big "FEATURE PREVIEW: MIGHT CHANGE OR GET DITCHED" label attached?
                    Cheers,
                    Lele
                      Cheers,
                      Lele
                      I'm not sure what I can say... but I will say that I will finally be dealing with a camera rather then a paint brush.
                        We recently had to do some sunrise shots with timelapse clouds. We used Dreamscape to do them and it worked out pretty fine. Rendertimes exploded tho as i had to render Spherical Reflection Maps at incredible sizes :P
                        Thorsten
                          LMAO!
                          This definitely disperses the mist
                          I just wanted to understand what we can expect from it from a Max interface perspective (it seems the 1.5 preview is fairly clear as to the features).
                          Ie. has it got f-stops, blades, and so on? Has it got some kind of exposure controls akin to real cameras, or f-stops work only to change the DoF, and so on...
                          I guess patience is the strongest of allies though, at this time :P
                          Lele
                            just a bunch of spinners
                            Eric Boer
                            Dev
                            • #15
                              aaaah geee!
                              even taken the piss of!
                              patience, Lele, patience.
                              Lele
