we still like vray
  • we still like vray
    hi to everyone here!
    this is my first post and i want
    to say thanks to vlado an his team
    for the good job they made.
    we use vray in our firm for nearly
    two years and there are many projects
    who never become true without vray.
    okay. as many of all the other user
    we look sometimes over the plates corner.
    surly you now nextlimits maxwell 1.0
    and the posts in the nextlimit-forum.
    i found an article over reproducing a
    photo an the big surprise like maxwell
    can reproduce the picture.
    and... yes vray can do it too!
    they don’t speak about render times.
    the rendertime of my reproduce in vray
    is maybe as high as the maxwell once.
    16 hours with ppt and 30000 subdivs.
    but i’m sure it can be faster!
    you will try it? here is the scene:
    www.kunstunit.de/download/vray.rar
    axel
    WOAH!
    Some first post mate!
    Confrabulations!
    I KNEW the ppt could do that, i SO knew it
    Now, what about that adaptive ppt which should be cleaner and faster ?
    Lele
      ah, theres one thing that should be tested also...
      Well, ppt produces caustics naturaly when you want...
      Now , what about saving the solution after some time, while its still very grainy,
      and making the rest fast and clean with i-map...
      should be much faster , shouldnt it ?
      thats what makes vray better. You get good results, but you also can tweak the immage to make it also with deadlines, which are killing bad for maxwell.
      Tom
        tom:
        yes, it can be faster and i agree with you this is
        the advantage of vray. and we don't speak about
        animations...
        here is a very fast one. of course now it comes
        with artefacts and the caustics lose details.
        settings:
          this has been done here, dough with different approach:
          http://www.chaosgroup.com/forum/phpB...ic.php?t=15147
          i m too lazy and gave up cause it got too hard to match the green red and white RGB and reflectance values....
          anyway....i m saving this for 1.5!
          Nuno de Castro
          www.ene-digital.com
          nuno@ene-digital.com
          00351 917593145
            another tiny script i prepared is a lightcache/ppt sample size and shading rate calculator.
            In ppt mode (sample size 1 pixel, or 0,0 in the vray panel) it allows to select the final shading rate for the image (the calculations about the image size are taken care of, ofc ourse).
            So one could do crops of a ppt, see at what shading rate it looks clean enough, set that shading rate, and set the final render off, knowing exactly what quality it will give.
            Which alone improved my rendertimes dramatically, particularly as i never reached again the insane subdivs amounts i used to, which went mostly wasted...
            I'll post it, if anyone is interested.
            Lele
              count me in!
              Nuno de Castro
              www.ene-digital.com
              00351 917593145
                Second that !
                nikki Candelero
                .:: FREE Your MINDs, LIVE Your IDEAS ::.
                  was i the only one to notice the maxwell one is really blurry?
                    not only that but the maxwell has a pretty severe caustic error/leak at the sphere
                    Eric Boer
                    Dev
                      ya its blurry. i wonder if its the noise reduction maxwell boasts having. I certainly hope its not post produced.
                        eric and percy, its not an error. Its actually correct. If you see the photo, its happening there too. Its glare, as maxwell's will call it, or as I would say light scaterring in side the lenz, remember my post on it?
                        Dmitry Vinnik
                        Silhouette Images Inc.
                        ShowReel:
                          well its alot blurrier then the photo, so they didn't implement it very well.
                            i'd have to agree with percy: it feels like their overboasted unbiased noise reduction does something VERY similar to an area filter reconstruction...
                            Which, guess what, VRay doesn't need for ppt.
                            Who's the unbiased here?
                            Here is the samples calculator i spoke about.
                            Be patient with me as this too is VERY ropey (doesn't read current setting, needs a render to refresh the rendersizes and so on. all the bells and whistles aren't on yet...), while doing the job.
                            I'll move it to the standard place @ studiodim.it on monday.
                            Have fun PPTing!
                            Lele
                            • #15
                              Jose said he added some blur in photoshop because the maxwell output was too sharp. I didn't notice whether he posted the original output or not. It is certainly pertinent information.
                              Perhaps the Vray render could be put alongside the photo and m~r render at the same size for a better comparison.
                              Surreal Structures
                              http://surrealstructures.com/blog
