Onyx Trees Causing Flickering in Animation?
  • Onyx Trees Causing Flickering in Animation?
    Does anyone know any good render settings to stop Onyx trees which are high ploy trees with lots and lots of leaves so that they dont flicker in animation. Im rendering out at 720 by 480 and using adaptive QMC at 3 and 6. Any help would be greatly appreciated
    www.jamesatilano.com
    i had good luck with adaptive QMC, min 1 max 5.
    quadratic AA filter.
    precalced IMAP/LC.
    no flickering leaves...
    Marc Lorenz
    ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
    www.marclorenz.com
    www.facebook.com/marclorenzvisualization
      And a tiny bit of render effect motion blur too - vray camera blur is too expensive and noisy.
        Thanks!!! I tried your rendering settings and there was a jump in improvement! does anyone else have any other settings I could try?
          Onyx leaf strangness
          I was working Oynx awhile back and found that one or two of the leaves would do random cartwheels. It looked like flickering from a distance but was actually the leaves spinning around in an odd way.
          It wasn't a bit enough problem for me to struggle through a solution.
          It might or might not help knowing that the leaves can sometimes go a bit mental.
            Antialiasing
            Adaptive subdivision: min: 0 max: 2
            Threshold: 0.01
            Qmc sampler
            Noise threshold 0.003 or 0.002
            That pretty much is what we use when dealing with flickering trees.
            Another solution is rendering at twice the frame size. It helps when trying to get rid of noise.
            Adam's comments make me think that sometimes u can find overlapped faces on some leaves which might cause the flickering too... That won't be solved unless u try and delete the offending leaves.
            My Youtube VFX Channel - http://www.youtube.com/panthon
            Sonata in motion - My first VFX short film made with VRAY. http://vimeo.com/1645673
            Sunset Day - My upcoming VFX short: http://www.vimeo.com/2578420
              Use Area filter for video.
              www.studio2a.co
                Have you tried collapsing the trees to a mesh, or make them into vray proxies. That might fix the problem.
                "Why can't I build a dirigible with my mind?"
