making glass not so perfect looking
  • making glass not so perfect looking
    http://static.flickr.com/72/202324363_aa7c6dbc82_o.jpg
    I would like to make the glass not so perfect with slight surface undulation that happens from the fabrication process.
    Any suggestions?
    using max 8
    vray
    res3d
    You can use a procedural texture in the bump slot, i.e. waves, noise, stucco, etc. Make several copies of the same material, and change the phase on the bump for each of the materials. Then apply the materials randomly to each pane of glass and you should end up with something that looks pretty close to what you wanted.
    Tim Nelson
    timnelson3d.com
      @ res3d
      Please stop posting in the Challenge section.
      This topic would be moved.
      nikki Candelero
      .:: FREE Your MINDs, LIVE Your IDEAS ::.
        grass with the fur plugin for max
        I'm sorry where should this kind of thing go?
        res3d
          hahah posting in challenges again hey res3d.. didnt I tell you about this last time.
          stuff like this would go in the General section ... (as it is now) and the rest is obvious... problems and bugs in the problems section, images in the images section..etc..etc...
          the challenge section is only for posting challenges like what is already there. So in other words..just dont post there again
            Haha
            It's an understandable mistake... Some things are just really"Challenge"-ing to get right
            Max 8 SP3
            V-Ray 1.5 SP2
            WinXP SP3
            Dual Xeon 3.4GHz
            2GB RAM
