Vray 1.5 Installed and running!!!
  • #31
    Originally posted by domi
    ..then can we start asking for the 64bit standalone?
    I will be happy if standrad 1.5 version is 64 bits ready.
    Luke Szeflinski
    :: www.lukx.com cgi
    • #32
      The V-Ray build for 3dsmax 9 has both 32 and 64-bit versions and will be available as soon as 3dsmax 9 is released.
      • #33
        you made my day Vlado
        Luke Szeflinski
        :: www.lukx.com cgi
        • #34
          Hah!
          That should be, "Vlado, you made my year!"
          rpc212
          "DR or Die!"
          • #35
            This forum is going to be a buss when people finally get hold of 1.5!
            • #36
              anybody got DR (or network rendering with strips) working yet with 1.5?
              Kind Regards,
              Richard Birket
              http://www.blinkimage.com
              • #37
                Did you check the manual on the CD for info on how to set up v-ray on the render slaves? Basically they need to be able to connect to the license server (although they do not need a license).
                • #38
                  yes - I think I have it setup, but I've obviously missed something. (well done at the demo the other day by the way - very impressive stuff)
                  The vray dialog box tells me that each of the slaves has loaded the scene and that they are starting to render, but their buckets don't appear. At completion, I have warnings for wach of the slaves telling me they are not responding.
                  In the instructions, I am told that each of the slaves should launch "vraydummy.max", but mine launch "vraydummy60.max" as with my older version of vray that I have upgraded from.
                  Kind Regards,
                  Richard Birket
                  • #39
                    hang on - just found something else I need to try.....
                    Kind Regards,
                    Richard Birket
                    • #40
                      You need to set up the render slaves so that they can see the v-ray license server.
                      • #41
                        yes, i've just done that. I've gone through to the 'Change Vray client license settings' and changed it to the IP address of the server (the same IP that the workstations themselves are pointed at), but they still seem to fail.
                        Kind Regards,
                        Richard Birket
                        • #42
                          If you look at the file c:\vraylog.txt on the slaves, what does it say?
                          • #43
                            Nevermind, send me an email to vlado@chaosgroup.com and we'll sort you out.
                            • #44
                              Another dongle question,
                              I have two dongles, one with 1 license and the other with 18, is there any way to figure out which is which?
                              Eric Boer
                              Dev
                              • #45
                                permanant marker with your choice of ink color i guess hehe
