Vray 1.5 Installed and running!!!
  • #46
    hehe....
    only thing I can think of is good old trial and error....slap one in and try starting vray on 2 machines. No matter what happens, you'll know....
    ME
    Talk nerdy to me...
    Matt English
    base2studios
    VizDepot.com moderator
    • #47
      Originally posted by vlado
      You need to set up the render slaves so that they can see the v-ray license server.
      so i need to modify 30 machines so that in their c:\program files...
      lives the client ini (or xml) file that describes where the server is?
      i am still awaiting my 1.5 for max8 so that's why the question
      rob
      throb
      vfx supervisor
      http://throb.net
      • #48
        Is the version on the cd from siggraph the same version that will be in the
        support section soon ? I ask because when I install from the disk it says
        "vray for 3dsmax8 rc1". Just want to be sure.
        Regards,
        Mike
        http://mikebracken.cgsociety.org/gallery/
        • #49
          Originally posted by tricky
          yes, i've just done that. I've gone through to the 'Change Vray client license settings' and changed it to the IP address of the server (the same IP that the workstations themselves are pointed at), but they still seem to fail.
          just trying to get this going today...not working here either...I'll go into more detail when we've exhausted all the buttons...
          e.
          • #50
            e.
            Any luck yet? I still can't get strip renders or DR working. I've been in email contact with Vlado and have sent him one of my test scenes that will not work this end, but he seems to have no problems. The scene will, however, render locally just fine. Very strange, and I need to get this sorted ASAP as jobs are waiting...
            Kind Regards,
            Richard Birket
            http://www.blinkimage.com
            • #51
              e.
              Yep, it looks to be working at least for DR, checking strip rendering now and I'll get you an update. I did get problems too a little later on after I emailed you and it took a while to figure out exactly what goes wrong.
              • #52
                I noticed the dongle uses WIBU key which happens to be the same licencing software as archicad uses.
                Just wondering i'f I will have a problem using both the archicad and vray dongle at the same time? (if there will be a conflict). Its only a minor inconvenience if i have to remove one dongle in order to use another but if it is a problem that would be handy to know
                Thanks and grats on getting 1.5 released!
                • #53
                  there shouldnt be an issue
                  Chris Jackson
                  Shiftmedia
                  www.shiftmedia.sydney
                  • #54
                    Cant wait to get dongle
                    And get up and running and give it a good test. I guess not being able to pick up a dongle from siggraph means all install questions will be up here ready for when all us others get them.
                    Simon Askham - http://www.supercreative3d.com Rendering with Threadripper 2990WX Asus Prime X399 36GB DDR4
                    • #55
                      this may be a question from a different book, but will i be able to install 1.5demo on top of the 1.46,
                      i want still work with a full version and play around with the new features of 1.5demo before getting my dongle
                      from what i understand downloading full 1.5RC from support will need the dongle.
                      DON'T LET SCHOOL INTERFERE WITH YOUR EDUCATION / www.ds4arch.com /
                      • #56
                        You'll only be able to run one or the other, if you really want both, best to copy your whole Max/viz folder and have two, one with 1.46 and the other with 1.50
                        Eric Boer
                        Dev
