vraysun.... at night
  • vraysun.... at night
    have anyone tried using vraysun/sky with the sun position under the horizon (in my case, under the vrayplane) ?
    it turns out.... Night ! though i got tons of 'material overbright' warnings and funny artifact around the object scene edges
    Harry G
    With the model used by V-Ray, the formulas used to calculate the sun/sky are not valid if the sun is below horizon, so it's best to avoid that - although ideally this should not produce artifacts in the render (I'll have to look at this).
      Will you be bringing in a night-mode for the vray sun? ie vray moon?
      Patrick Macdonald
      Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
        i see... thanks for the explanation, Vlado
        though i found that placing the sun a bit under the horizon still produce quite nice sunset effect...
        and when placed further down under the horizon, the sky turns really dark blue which, well, as i said..... night sky, quite realistic, while still producing dark blue GI to the scene
        yeah, maybe vraysun/sky that works at night would be nice... something for the 'wishlist' ?
        Harry G
